1 - 13 of 13 Posts
4.500" billet crank -- Sold
Jeff Johnson (Billet Fab) dry sump oil pan with three scavenge tubes and 4" kick out with starter pocket --$600.00
SBF fluid damper balancer w/ sfi numbers -- $225.00
works well with danny bee belt drive
BBF fluid damper balancer -- Sold
Ford Racing valve covers -- Sold
GZ Motorsports vacuum pump (dyno time only on it) with drive pullys and mounting bracket -- $500.00
2 sets of brooks aluminum rods run one season each with 2.200 journals and .990 pins 1 set 6.800" 1 set 6.840" -- $200 each
Crane pro series lifters for bbf with straight tie bar -- $200
3 cam shafts for bbf all 288 @ .050 or larger intake lobes e-mail for details, questions, and phone number -- $175 choice
Push rods in sets of ten all 3/8" heavy wall (smith bros) with 5/16" ball ends 10.450", 10.320", 10.300", 10.180" -- $50/set
All of these parts have been used in our engine program at some time and are in good condition aside from being slightly used. If you are interested --
Email [email protected] or visit our web site :)
Sticky in Chilly's Garage tells how to post a pic.
re
The lifters have two seasons on them about 70 passes. Still pretty good shape.
I used the big block damper on a scat billet crank with the short 429 snout about 3.5" from bearing to end and it worked fine.
StrokerDriver said:
4.500" billet crank, fully counterweighted and knife edged, std. rod and mains (never been hurt) with 2.200 rod journals. -- $1500.00
BBF fluid damper balancer w/ sfi numbers -- $225.00
Ford Racing valve covers tall cast w/ black lettering Knock outs still in place but have 1 hole in each for -12 vent tubes / vacuum pump --$75.00
4 cam shafts for bbf all 288 @ .050 or larger intake lobes e-mail for details, questions, and phone number -- $175 choice
what brand is the crank?
Crankshaft and pictures
The crankshaft was done by crankshaft specialists from Tennesse. I bought it new and it was not a rechrome.
If you are looking for pictures please just email me and I can send them your way.
1 - 13 of 13 Posts
