C & C motor sports Alum block ( solid no water )
ALL parts were speced by Carol Carter @ C and C motorsports I can answer questions and of course Carol knows every detail about this motor also. feel free to call him too.
Billet Velasco Crank, CNC ported C and C motorsport HEMI heads - solid
Gear drive assembly, mag drive Jesel shaft rockers, Manton PRds, 3 stage dry sump, front engine drive
Arias custom pistons 11.7.1 ( 2 extra pistons ) Nick Arias/ Carol Carter speced.
MGP alum rods 2 extra rods
Blower Intake C and C motorsports, billet Intake spacers,
Crank support, dry sump pan, block bell pattern for Big ford or Mopar, Deg ring w magnets, Boss alum valve covers w blow down tubes, burst panel fuel pump drive. C and C motorsports Cam
I have ALL receipts and part numbers.
4.125 Stroke X 4.5 Bore
Motor is 100% NHRA legal and set up for blown alcohol, with right cam could easily be a turbo motor.
This engine has NO provisions for water. Completely balanced, fully blueprinted.
I can fax the parts list from C and C. only items purchased separate were pushrods, rods, and they were per C and C specs.
$25K Located In Indy.
No blower, No mag. I can throw in a nice set of zoomies if they fit your needs.
317 927 5890
hi jerry,been a while.
going a diff route?
Engine still for sale $25K for a 2500-3000 HP blown alky motor you can put this in a pro mod or a TA/FC Put a screw blower on it and race with PDRA
I will separate the heads/ block Intake.
Heads are race ported from C and C motorsports and have no water jacket. Shaft rockers are jesel, push rods are 9/16 Manton. 11K for the heads n hardware and will throw in the zoomies.
short block $15K billet velasco crank, block is solid aluminum with sleeves @ 526 CID.
call for details
317 927 5890
