2 sets Aluminum Blue Thunder BBF heads, Chevy exhaust. closed chamber 1 of each set probably broken beyond repair.(Througt seat into port.) 1st set stage 3 ported 2.3 & 1.880 valves(need 1 intake 1 exhaust) titanium retainers roller springs .750 lift with about 25 passes on them gide plates & studs. $900
2nd set same as first - only bowel clean up no porting ,need 1 intake 1 exhaust valve
$900
Comp cams roller cam BBF New 34-746-9, Intake .796 285 @ .o50 Ex .726 [email protected] .050
$250
Used Lunati solid roller lifters BBF good condition $150
6 pair used Lunati solid roller lifters BBF $100
Holley electric 250 gph pump never had fuel in it $200
Holley 750 vac secondary 3310-3 with dual feed line ,choke flap missing $100
Coan Converter 8" Turbo input 6000 stall behind sbf $350
C-6 8" converter 4500 stall behind bbf $300
C-6 10" tight leave race converter 3000 stall $300
H beam rods used 6.7 length 6 Manley 2 eagle 990 pin ford main $175
Every thing plus the ride All parts will be at Norwalk 7/23 to 7/25
Denny 330 842 1886
$900
$250
Denny 330 842 1886
