$905 with adjustable lower control arm bracket (11 holes) AND your choice of strange engineering axles 28 to 35 spline, bearings and wheel studs.
Lots of options!
$165 Back brace installed
$318 Upper and lower control arms FREE SHIPPING (limited time)
Can get strange race axle's 40 spline gun drilled and components ECT
Can get Moser axles and components!
Complete center sections available!
Any housing end available
Brake kits race and street.
[email protected]
Call 608-313-9197
http://trickchassis.com/trickstore/
https://www.facebook.com/TrickChassis
These are 100% new housings ladies and gentlemen, 1/4" wall 3" axle tubes choice of housing ends, can be ordered with standard upper brackets or adjustable brackets for a double rod-end double adjustable upper arm. Brackets can be moved on the tubes as needed just let him know when you order.
Also has fabricated housings available call for pricing and options.
We can build a 9" for just about anything you would need, if you have measurements just call and ask. We can build you custom lengths, custom brackets, custom pinion offset...
Ladderbar, leafspring, and coil-over brackets available as well (can be installed on new housings to your specs as well).
Fabricated housings available, 3 1/4" axle tubes available in the fabricated housings choice of Moser, Strange, Quick Performance housing ends in the style of your choice.
Double adjustable control arms with spring perches and/or sway bar brackets are also available.
The website is in the process of being updated to show all the current products and customers projects. For now best thing to do is call
