Status
Not open for further replies.
1 - 3 of 3 Posts
540 alcohol injected /Boss 9 block / oil pan to injector flywheel to balancer
Complete Boss nine block 540 cu in. Old style AR / SCJ heads ported by abbot racing heads of texas,roller rockers, oringed block and cylinder heads, block does have one sleeve, dome pistons, aluminum rods, production crank that has been welded and offset ground, large roller cam (specs unknown) crane roller lifters, fluidampner, rear sump pan, enderle 80A pump and bug catcher injection on a offy tunnel. Complete from pan to injector and flywheel to timing chain , no front cover. This engine has not ran in 7 years and is currently partially apart just to verify what is what. It only had about 25 passes on it and was parked because the car it was in was not certified to run in the nines. This engine ran 8.80's @ 158 in a 2900lb Boss 302 Mustang drag car. Included is an alcohol moon tank with the lines for the injection. Looking for $4500 complete, may seperate, but the engine will need freshened with a gasket kit. It is somewhat apart for anyone who wants to inspect what is here.
Travis
Flintstone, MD.
1 - 3 of 3 Posts
Status
