How everyone doin??? the dash light that says brake is contstantly on. This is on my 86 f250. disc up front drum on the rear. I started to flush the brake system and only got past the rear wheels and had to stop due to weather. What si causeing the brake light to be on? The e brake is not hooked up and I have pulled the release lever many time still no change.any help?
it isn't uncommon for a perportioning valve to be stuck if you had a brake problem i have had to open a bleeder and tap on it or even bleed the side thats working to get the other side to work
re
Yeah i only got half way done bad dust storm rolled in didnt want master cyl open with dust flyin around. the fluid level is normal. So by finishing the brake bleed and trying to bleed the perportioning valve it should clear it up? I can still peg the brake pedel to the floor with out effort even after flushing out the lines and bleeding the rears.
