1 - 11 of 11 Posts
We have a brand new pr of C 460 cly heads for sale with new ferrea titanium intake valves and new ferrea steel exh valves. The heads have been c&ced, comp valve job, flat milled ready for assy. the intake valve is 2.450- 6.470 long #F1693 , the exh are 1.900- 6.240 long #F1264p . These heads have the best C&C program done on them. Also A comp cam by Evens it a 894X887 with a dur @50 of 288-312 its a new solid roller still in box. also a new set of WW shaft mt rockers complete still in the box which are 1.75 ratio. A new set of pro stock springs that can be set up at #480 seat pressure. We can assemble these heads for you. The complete package is $7500. + shipping. Located in Kal Mi
What the rpm range of cam? What was the intended purpose of these heads? Also, why did u decide to use shaft mount rockers instead of stud mount? Thanx again.
C heads are generally for higher rpm applications 1100-1200 hp range
They only offer shaft rocker arms for them
comp cam
Yes this is a custom grind cam by Charlie Evans Racing the cam has a swap firing order and has a 117 lobe seperation. which is good grind for nitrous the rpm range would depend on your bottom end. should be good for 8500. thanks hope this helps.
Yep that helps. Any chance you can send pic of shaft rockers to my cellphone? Does it eliminate the need for a girdle? Thanx again.
Hey 68formalgt, do you have c heads on ur motor? are all c heads shaft mount or just newly made ones? What about 18 bolt D heads? What's the difference between C an D heads? Am curious as to which is better. You can respond to me directly by text 4847073453 if ur ok with that. Thanx
1 - 11 of 11 Posts
