1 - 7 of 7 Posts
BRAND NEW SUPER WINCH 1440
Normally $374.00
$350.00 SHIPPED! OBO!!
Still in the box.... just have to get rid of it! Thought it would be useful to someone!!!
S4000 1440200 Standard Features
Power Load IN and OUT
Mechanical and Dynamic Brake
Full-metal Gear-train
Freespooling Clutch for Fast Wire Rope Payout
High Efficiency Low Amp Draw Motor
Commercial Grade Integrally Mounted Sealed Contactor
Circuit Breaker Protected
Durable Handheld Remote Switch on 30' Lead
Roller Fairlead
S4000 1440200 Performance 12VDC (1st layer on drum)
0 lbs. Line Pull / 32.0 FPM Line Speed / 30 Motor Amps 12V
1,000 lbs. Line Pull / 16.0 FPM Line Speed / 90 Motor Amps 12V
2,000 lbs. Line Pull / 12.4 FPM Line Speed / 155 Motor Amps 12V
2,500 lbs. Line Pull / 10.6 FPM Line Speed / 180 Motor Amps 12V
3,000 lbs. Line Pull / 8.8 FPM Line Speed / 215 Motor Amps 12V
3,500 lbs. Line Pull / 6.2 FPM Line Speed / 250 Motor Amps 12V
4,000 lbs. Line Pull / 4.5 FPM Line Speed / 311 Motor Amps 12V
S4000 1440200 Specifications
Rated Line Pull (Single Line): 4,000 lb. (1,814 kg)
Motor: 1.8 hp (12V or 24V DC)
Gearing: Differential Planetary
Gear Ratio: 159:1
Freespooling Clutch: Lever action
Braking: Mechanical and Dynamic
Wire Rope: 7/32" x 60' (5.6mm x 18.2m) with Latched Hook
Dimensions: 15.1" l. x 8.7" d. x 6.0" h. (383mm l. x 221mm d. x 152mm h.)
Drum Diameter: 1.625; (41.3mm)
Drum Length: 3" (76.2mm)
Weight: 40 lb. (18.2 kg)
Switching Method: 30' Rubber Handheld Remote
Switching Mechanism: Commercial Grade Contactor
Roller Fairlead: Standard
Wireless Remote Control: 30' Remote Lead!!!
Shop - 660-646-4553
Cell - 816-390-0852
Email - [email protected]
Normally $374.00
Roller Fairlead
Gear Ratio: 159:1
Shop - 660-646-4553
Cell - 816-390-0852
Cale let me see where I'm at this friday ( payday) and see if I can swing it.
I really need one for my trailer
Ace
Check Your PM's
BOTH
hmm i guess i could have read everything....right there in the write up. :)
once i finally get my super outlander back from the engine shop we'll see if the winch can hack another winter of plowing. Last winter was hard on the 2.5ci.
1 - 7 of 7 Posts
