Installed the bronze distributor gear today during lunch. It was pretty easy considering my friend from KRS machining was helping: KRS means Kiss ouR *** Machining LOL :shock: - He has a sign and everything :lol:
I measured the distance of the old gear to the end of the shaft as a reference point
Knocked the old pin out with a punch and then pressed off the old gear.
Per MSD's instructions, I rotated the new bronze gear 90degrees from the original hole (Why couldn't they make this simple) and then pressed on the new bronze gear. Checked the distance and we were 0.010" off :roll: so I applied 0.010" of pressure to the gear with the press :lol:
I was just going to set it up in the bridgeport endmill and drill the 0.125" hole through the shaft using the gear as a guide but my buddy Kelly wanted to get fancy so he set it up in his CNC Mill :idea: and took a reference off of a 0.125" broken bit sticking out of the bronze gear where the roll pin goes and then drilled it with the CNC 8)
knocked the new roll pin through......... And that's the rest of the story
Easy as pie!
Easy as pie!
