Price isn't a factor here. Quality is the priority and I want to buy the best part the first time. I'm using a short snout 4.5 Bryant crank with a Danny Bee cam drive. Also using a .250 engine plate and MSD BB crank trigger wheel (7.250) diameter.If anyone KNOWS what damper works best with this setup, would you please fill me in ? Iv'e been leaning toward an ATI unit P/N 917564/. However, ATI offers a large or small diameter, aluminum or steel, and I see where some are using a small block damper. Please advise!
Thanks, Ross
ATI, If you want the best
Use the small block hub for the boss snout, and the 7'' dampner .
You will need a spacer behind the hub to move it out from the danny bee a little.
PETERSON PUMP now sells a mandrel that bolts on with no mods if you need one.
call ask for PAT , tell him Rich sent ya
You will have to reconfigure your timing pointer for the danny bee a little
Ditto to what Boss 429 said. I have used the same setup. But on my last build I had ATI build a longer hub for my dampner, eliminating the spacer. It is kind of pricey, but you can also specify where you want to place the TDC mark on the dampner.
Bryant crank /Danny Bee-Damper advice
Thanks very much to the both of you for the advice. Turning out a spacer isn't a problem. You saved me from purchasing the wrong ATI P/N. What I see according to ATI, is P/N 918022 which answers the 3 bolt pattern question and no aluminum option here. TX again! Ross.
