In conjunction with my cam grinder I am offering Cam and lifter kits reground on the original ford BB cam cores or used comp cores for grinds larger than 220 @ .050". Kits include our same branded notched lifters we always use.
Any shelf or custom grind hydraulic or solid flat tappet is available.
As a note the original ford cam cores are 4 to 5 points harder on the rockwell scale than the cores we have available today new. These are not second rate cam kits. I am using a regrind in my 12.99 LTD project.
Cost is $149.95 plus shipping.
For those of you who need mild cam grinds with non adjustable D3 or EFI heads new elgin pushrods are available in .030" longer increments to compensate for the reduced base circle. Cost is $30.00.
This special will be available as long as the supply bin of BB ford cam cores hold out. ;)
:D
Discussion Starter #2
As a special note the cam I am running in project 12.99 LTD's 500+ HP 460 is a small lunati grind on an original ford BB core.
The cam and lifters were donated as a courtesy by my cam grinder. I could have had a new core but wanted to utilise a reground cam to emphasize that they are a good option.
:D
