1 - 18 of 18 Posts
RHP has cut a deal with our cam grinder to have available reground cam and lifter kits for $119.95 plus shipping.
These cams are reground on the original factory cores and utilise a reduced base circle to allow increased lift and duration. They are parkerised and the lifters are notched.
The factory cores will allow cams of up to 230 @ .050" lift duration and are best suited to juice grinds.
8)
Discussion Starter #2
TTT
N/M
TTT
N/M
TTT
I have used these cam kits in many of my personal and budget builds with no issues whatsoever....
8)
TTT
n/m
8)
TTT
n/m
8)
ok
I dont get it are these cams new or the word reground???I need a bigger cam for mine bbf..I run c8ev,s that are port matched to my victor manifold and ported on the exh side for better flow.My cam now is a Lunati with 609 lift..which way to go next?
Re: ok
These cams are ground on the original factory cores. They are not new hence the lower cost.
8)
Discussion Starter #12
wesperkins said:
what it the max achievable lift using 1.73 rocker arms?
Thanks,
Wes
.600" give or take. Depends on duration...
8)
i'll give you a call on monday, so we can talk about it. Im building a mild strip motor and would like your recommendation on the cam for my build.
Wes
Discussion Starter #14
Wes
I would be happy to talk to you Wes...
8)
Hi Scott,
I have two questions...
(1) What is the cost to repair one lobe on a solid roller cam (mild damage)? It is a Comp Cams core.
(2) On a solid-roller re-grind, how much can the lobe seperation be changed? Cost?
Thanks!
Discussion Starter #16
BBBob_M said:
Hi Scott,
Thanks!
Bob,
Give me a ring at 253-988-6648. I will check into the repair. cost for regrind is $100.00.
8)
Discussion Starter #17
TTT
8)
Discussion Starter #18
ttt
n/m
8)
1 - 18 of 18 Posts
