1 - 7 of 7 Posts
Happy summer!
I'm looking for some build advice. And, I have read the sticky! LOL! Probably not many do...
I am looking to make my car a bit of a sleeper, and wake up the dog I now have under the hood. I'd like to build the engine up to a PI standard, or even a bit more. But I'm unsure about pistons to use, compression ratio to aim for, camshaft/lifters, exhaust sizing, etc. Right now, the 460 is stock, except for a 1968-70 timing chain I swapped last year. THAT woke up the engine a lot, but it is burning oil a bit, and then I blew a head gasket last fall...
So, time for a rebuild!
1) street use
2) 1974 Ford LTD Brougham 2 dr hardtop, 4200 lbs, C6 transmission, 2.75:1 rear ratio
3) Premium fuel, no ethanol
4)Parts I have:
-Edelbrock 2166 Performer intake manifold
-Edelbrock 1906 AVS2 650 CFM Carb
-D2OE-AB heads (rebuilt)
5) $5K give or take
6) I have a machine shop already.
I am willing to change the rear differential ratio; I'd like a limited slip possibly. The transmission has been rebuilt; I'd be willing to beef it up if need be.
All help is appreciated!
Any bowl blending or port work?
SJ
used 2b RHP
They have been ported, and are smooth, but not a mirror finish. They haven't been blended.
Porting typically starts with bowl work.
Mirror smooth and pretty are a waste of time. Shape is paramount. Aesthetics are pointless other than presentation.
SJ
used 2b RHP
I'm wondering what pistons I should go with, as well as a cam recommendation? I'd like to make the most of the heads, but at the same time I don't want to go overboard and waste money on upgrades that may not do much.
I would go with a Clegg 521 kit for the rotating assy and somewhere in a 280/580 cam roller tip rockers big tube exhaust a good dizzy and msd ignition
With ANY BBF IRON HEAD a single pattern cam is inappropriate and will cost peak power.
Ported or not the typical iron head has an I/E ratio of about 58%. 13 to 16 additional exhaust timing works best.
A dual pattern cam will carry the HP peak higher and hold on longer after peak. Use one.
15 to 20 hp going from a 230 / 230 to a 230 / 236 shelf grind and another 10 to 15 going from that to a 230 / 244 or 246.
SJ
used 2b RHP
1 - 7 of 7 Posts
