1 - 7 of 7 Posts
Ford C-460 Heads Full CNC and Competition Valve Job.Flow 6cfm to 590cfm. 500cfm at .900 Int. Exh. flow 5cfm to 481cfm. 371cfm at .900 1100+ HP. Spring cups.Manley Ti.Valves 2.450Int. and 1.88 Exh.Triple Valve Springs 2.200 Installed Height 350# Closed 1070# Open Coil Bind is 1.142 . Ti Retainers & Locks. $6680.00 (Minus Lash Caps)$500 Security Deposit with Balance due on Delivery
Re: C-460 Heads Full CNC and Competition Valve Job $7000
blackjackhp said:
Ford Motor Sport C-460 Heads Full CNC and Competition Valve Job. CNC Flow sheets Read 6cfm to 590cfm with a flow of 500cfm at .900 for intake and. flow 5cfm to 481cfm on the Exhaust with a flow of 371cfm at .900 these are 1100+ HP. Ford Motor Sport Roller Rocker Arms 1.8 Ratio Ford Doesn't Make these any more. Ford Motor Sport Roller Lifters with Offset intake. Ford Motor Sport Chromoly Valve Spring Seats. Valve Seals for triple Valve Springs.You will Need Taller Triple Valve Springs with an installed Height of 2.200 to Run a High Lift cam. I have a set with an Installed Height of 2.100 that I was going to shim By .050 with a Cam that had a lift of .829 Intake and .789 Exhaust I can Add the Competition Cam's Triple Valve Springs That I Have so you can Trade or sell to get some Cash for the Bigger Spring's or Just shim and run untill you Want to Change these they come with Manley Titanium Valve's 2.450 on the Intake and 1.88 on the Exhaust. Titanium Valve Spring Retainers and Chromoly 10 Degree Machined Locks. All Packed and Ready to Go 3 Boxes 1 is 42# and the heads are 44# Each. $7000 all the Littel Pieces are Here No Hunting for Parts to Buy. Thanks Jack
Re: C-460 Heads+ Intake Full CNC and Valve Job+Ti Valves
Ford Motor Sport C-460 Heads Full CNC and Competition Valve Job. CNC Flow sheets Read 6cfm to 590cfm with a flow of 500cfm at .900 for intake and. flow 5cfm to 481cfm on the Exhaust with a flow of 371cfm at .900 these are 1100+ HP. Ford Motor Sport Roller Rocker Arms 1.8 Ratio Ford Doesn't Make these any more. Ford Motor Sport Roller Lifters with Offset intake. Ford Motor Sport Chromoly Valve Spring Seats. Valve Seals for triple Valve Springs.You will Need Taller Triple Valve Springs with an installed Height of 2.200 to Run a High Lift cam these they come with Manley Titanium Valve's 2.450 on the Intake and 1.88 on the Exhaust. Titanium Valve Spring Retainers and Chromoly 10 Degree Machined Locks. All Packed and Ready to Go 3 Boxes 1 is 42# and the heads are 44# Each. $7400 all the Littel Pieces are Here No Hunting for Parts to Buy. Thanks Jack
BUMP
1 - 7 of 7 Posts
