1 - 9 of 9 Posts
I have a 1994 F-250 4X4, with a C-6 Transmission, it has 55000 original miles on it, but I am experiencing problems with it shifting.
When just accelerating slow it will shift up, and downshift repeatedly until I give it quite abit of throttle, then it will shift correct, this happens in both 1st to 2nd, and 2nd to 3rd. If I accelerate half throttle through full throttle it will shift through the gears great.
Any ideas as to the problem?
Thanks,
David
hi Dave,
Does that newer trans have a vacuum modulator valve? I had the vacuum hose break one time on a 1972 C6 and it would only shift at a fairly high RPM.
Yes it does, that was my first thought, and I checked the hoses and all were hooked up, maybe I just need to trace it and replace it to see if it has a small break that I can't see.
I just got home from the races, and it pulled and shifted great, but with the 5.8 I have to keep my foot in it to pull the trailer and 5000 lb. race truck, and like I said, when you have your foot in it, it does great.
What about it guys, no clue to what this could be?
could be an issue with the governor?
Honestly I'm not really in the know on the non electronic shift controls.
give me a pcm controlled unit or a full blown manual vb-trankbrake etc I'm your man.
I have seen c4 do this on the 1-2.Not the 2-3 but i guess it is possible.Here is a quote for C6 from a transgo book i have.
Complaint: Bump-Bump-Bump at 8-12 mph
Cause: Governor not stabilised allowing rapid shifting up and down from low to second
Fix: Install transgo SK6-7 shift kit
Sounds like the governor might be the problem, now a dumb question, where is the governor located?
Thanks for the replies.
take off the extension housing and here is a pic of the governor.
:mrgreen:
Thanks for the illustration, that looks easy enough. I will check in to this. 8)
1 - 9 of 9 Posts
