1 - 8 of 8 Posts
Well at the end of this pulling season My Buddy Bruce will be putting his current 535 CID C-headed Monster up for sale. Less Carb, Dry Sump and Oil pan. He'll be building a new motor over the winter with A-460 Heads.
After many hours of discussion we have come up with it'd be cheaper to build a new motor then try to put A-460 heads on his current motor.
So Charlie I'll try to steer him your way for the new stuff .. Heads, block, rotating assemble..
So if anyone is interested in this motor email me .. He's talked about letting it go for $10,000.00 ..
ShaZam
ShaZam,
Was your truck out-pulling his truck? We've seen a tendency for the A headed engines to have more low end torque than the C headed engines. But then, the C headed engine will make more Hp on the top end, with all other factors being equal. The torque curves have a different shape, but usually the gearing and the convertor can be adjusted around (played with) in order to make best use of the torque curve.
That sounds like a very good deal on that C headed engine!
535 CU IN MOTOR
Block
Rotating assembly type
Compression
cam
Head Flow #s
carb size
what type of rpm's does it turn.
will it need to be freshened.
how long before he's done with it.
location
Greg
OK
Block is a SVO A-460
Heads Ford C-460 heads with Cranes Shaft rockers.
Rotating assembly type is Crower Crank, Bill miller Rods, Viladon Pistons.
Compression 14.5 to 1
cam Special grind from Engine systems .
Head Flow #s He's got them somewhere .. But had a stage 5 porting done to them on last freshen
carb size 1300 Domi.
what type of rpm's does it turn. 7500 to 8200
will it need to be freshened. Yes
how long before he's done with it. Last pull of the season will be Sept.16.
location 6 miles North on Hwy 180 Marinette, WI 54143
Hope this helps ..
ShaZam
1 - 8 of 8 Posts
