1 - 7 of 7 Posts
Engine Systems/Ted Fischer prepped C460 heads, dyno time only since freshened, 490in, 380ex. WW 1.8 shaft rockers, pushrods and matched C460 single four intake for the heads. New Cam Motion 936/860 roller camshaft, Comp Cams z-bar roller lifters with dyno time. New, never run JE 4.628 C-head pistons, Crower 6.700 billet rods with dyno time, Nice Scat billet 4.500 crank 60-65 passes, Used, never broken, 4.600 bore A460 block with roller cam bearings, bushed lifter bores , O-ringed and main studs with used C-head pistons. Also, 18 bolt C-head bolt set, everything, $10,000. Thanks Jim
1 - 7 of 7 Posts
