1 - 7 of 7 Posts
I am running a c4 in my 472BBf fox body mustang and having problems with the planitarie seizing up...Has anyone used the roller one from Broader Trans????Or get the one from P.A. trans....With the 6 gears???Thanks for your help...
With big power and or high rpm the std thrust washers under the planet gears will fail. The torrinton bearings resolve this issue. The other weak spot is in the pins.
S
Guest
My Trans parts are from Jay at Broader Performance
His number is 817-599-9400
I built a full roller using Jay's parts..
I have a pan fill 1970 version transmission and removed the check ball & spring in the pump for full oil flow.. I tapped and installed an allen set screw plug in the hole..
Laters!
1 - 7 of 7 Posts
