1 - 10 of 10 Posts
This is the kit you need to put 2.75:1 first into your C6, or upgrade your E4OD's crappy 3 gear aluminnum planet assembly. I bought these last week at Transtar to upgrade the C6 in my motor home. I tore it down, and found that the only thing wrong with it was the band needed adjusting, so I no longer plan on using these parts. I have about $350 into this stuff, cant take it back, and need to get $300 out of it. This is everything you need hard part wise to make the upgrade
73939DN PLANET INPUT 6 PINION E4OD 97-UP AFTER
73954b Hub w/ thrust bearing- forward 89 up
73973d Shell - Sun gear, second design, hardened, 89 up.
73974 Sun gear, reverse
73955-r Ring gear front, with hub, 89-96
[edit]I also decided to not take the trans completley apart, so I have a delux rebuild kit with raybestos clutches, I'll let go for $100. It has a green stripe modulator, a HD 2.5" red band, everything you need except for bearings IRC. K3600B-R
http://www.shinseiauto.com/japanese/transtar/usforde4od04.pdf
Email me at [email protected] with any inquiries, I dont check here very often.
R
Guest
theres no way both Shane or I combined could ever top you Randy......
I got an open heart patient waiting on a some tranny parts, git er done......
Here is what you are buying. I have never opened the boxes (cept for one that was not sealed)
Tony
(530) 621-3224 after 6pm
Randy I just read that again and you know, I think your probably right !!
I just got a laugh out of that!! :lol:
1 - 10 of 10 Posts
