1 - 9 of 9 Posts
I have a bunch of C6 parts that I dont really need anymore... they were from 2 transmissions, they are from 1976 thunderbirds. Heres wat i got, basically i have one complete trans in parts and a complete rebuilt forward clutch assembly with red alto clutches and kolene steels.
2 long tailshafts (lincoln type)
2 Long output shafts (1 shaft still has govenor installed)
1 complete Valve body
1 complete set of parking linkage
1 complete pump with stator
2 "P" servos
2 "A" (i believe) servo levers
1 input shell
1 low reverse clutch hub
i have 3 pinon planitaries
The main thing i have is!
A brand new rebuilt complete forward drum clutch assembly with 4 red alto clutches and Kolene steels with matching ring gear and 3 pinon aluminum planitary. This this was rebuild with new seals etc and i ended up having to get a whole new forward drum assembly so I could stick 5 clutches in it. I also have the extra clutch to make the assembly 5 clutches (in the 4 clutch setup i have for sale) but you will need to get a step machined pressure plate. this thing is ready to bolt in and has HIGH PERFORMANCE red eagle ALTO clutches and kolene steels! has an extra clutch for more power handling!
Discussion Starter #2
oops i forgot to add prices!
Not really sure about the internal parts or VB, I know what i paid for the short tailshafts so i would sell the long ones for like 30$ each.
Output shaft will be 30$
output shaft with govenor will be 45$
VB will be like 100$
Servo levers 10$ each
The assembled forward drum clutch assembly I would sell for like 150$ as i paid well over 200$ for the forward drum clutch assembly that i have now and it only has 5 borg warner clutches inside. My forward drum assembly has 4 RED ALTOS!! I even have the 5th clutch so you can install it yourself... all you need is a stepped pressure plate! they are cheap! ( i didnt know this and bought a whole new assembly).
All prices are negotiable so please make an offer! I want to not have this stuff laying around!
which one? reverse planitary (low reverse clutch hub) or the planitary carrier assembly (fits in ring head foward clutch assembly/sun gear).
Do you just want the planitary or the parts that they fit into too? Just saying So i can price accordingly.
OK....in all honestly im kinda C6 ignortant as of right now...lol
I have the low E4OD gearset in mine now....i hate it and wanna go back to stock C6 ratio's.
So......i guess whatever that's called is what im needing.
WEll im attaching an exploded view of the C6 trans. I Circled the planitaries and I put a SQUARE around the parts that I think you might need to. Im not totally sure on what is needed for the gearset change. Ive only built 1 C6 but I had 2 transmissions to choose parts from.
let me know exactly wat you need. I basically have everything of one complete trans and some extra stuff
lol prob out racing!
I did some research and it seems that for the swap u need (planet gear, hub, bearing, ring gear and sun gear and you will need a C6 sun shell) the E40d has a different sun shell apparently. Also your foward drum might not fit but it should. You will also need the new thrust washers etc.
Thats everything I have, you should be able to swap back with what i have, I also have the thrust washers.
1 - 9 of 9 Posts
