TCI RV Converter. #443610. It has the 1.850 pilot on the front. This converter has probably 3000 miles on it. My plans for the car changed, so I don't need an RV torque converter anymore.
This is $271 from Jegs.
From Jegs.
"This gas-efficient High Torque Towing Converter is designed to reduce the slippage found in all non lock-up torque converters. This series of torque converters enables transmissions to run cooler and reduces engine RPM at highway speeds. In addition to the resulting fuel mileage increases, the High Torque Towing Converter also lowers transmission temperature by as much as 20 °F. This is an excellent choice for motor homes, tow vehicles and other heavy load applications."
I will say I did achieve decent gas mileage (13+) with this converter.
Forgot I still had this in the garage.
Anyone interested?
