I have a full manual C6 behind a 550 hp bbf. I have an H servo that I notched the first (smaller) piston. From what I was told, this effectively increase the piston size. As part of this mod, I am going to tap and plug the hole with an 1/8" pipe plug.
I currently have an 'A' arm. Considering the piston mod, which lever arm should I get (A through F)?
Have a good day!
MIchael
Is that an aluminium piston or molded rubber? With a large apply just about any lever will be fine. Just have to watch though the high leverage arm and a big apply area can crack the case at the band adjuster.
It is a modified aluminum piston-- I notched the first (smaller) piston. This means the hydraulic force is now against the 2nd (larger) piston.
Have a good day!
Michael
