21 - 40 of 72 Posts
Frank got a another ? for you can i take out the downshift rod out of the shifter rod and fill it with rvt i'm asking because i cut off the threds to the downshift shaft so i cant put back in the o ring and nut.I'm going to look at my c-4 in my cobra two i think thats how performance automatic does it.
Thanks again gonna run it tomorrow and see how much it helps going from stock valvebody to a full manuel unit.
What i did lastnite before i read your post is i moved the downshift lever all the way to the inside untill it hit the drum and cleaned the rod and inside the shifter shaft with brakeclean and put rvt on the rod and inside the shift shaft and then slid the rod back into the shaft and let it dry over nite my ? is does that rod need to move around in there ? i didnt think so because you have the nut and o ring on there usally i just want to make sure its not going to screw up the trans tomorrow, if it leaks a little no big deal i'll fix it right this week with a cup plug like you said is this a ok temp fix?
encolfela
DO NOT CLICK ON ANY OF THE LINKS FOR PORN THAT ENCOLFELA POSTED ABOVE ! THEY ARE INFECTED WITH A REAL NASTY TROJEN !!!!!!!!!!!!!! MODS, THESE SOULD BE DELETED !!!!!!!!!!!!!!
C-6 Trans Build
Got a few questions about Frank's build thread. maybe some one else has been there? In the forward clutch I used the new style drum (w/ the .400 bearing pocket) w/ the wave plate, and was able to put 5+5, and used the flipped internal press. plate. The problem is that there is way too much clearance, (I can put another snap ring in) it ends up @ .080-.084 clearance. Is that ok with that configuration? Did I miss something? I used the same ring gear assy. that came out behind it also.
How can you tell which high/reverse drum you have? long or short spline? I need to figure that out so I can machine the right dimension snap ring groove. W/ 5+5 the clearance should be @ .060? Also the step cut in the press. plate should be .165 deep? x how wide? Thanks for any help, don't want to have to do this more than once. Thanks,
Mike
Discussion Starter · #35 ·
first check your stack height on your front planetary and ring assembly for the .400 deep forward drum pocket, there is selective snaprings for the clutck packs ie ; .043" .056" .066" ,076' .086" .096" .106" with a stock 3 clutch high/reverse drum with 5 cluctches you will not have to mod the pressure plate ,on cutting the new snap ring groove have your machinest with a .125" snapring groove cutter register in the orginal snapring grooves outtermost edge then cut a new groove .325" farther out leaving the section in betweem the old and the new groove
Frank
Hey Frank, do you rebuild complete trannys? I have a TCI C6 with your Transbrake V/B fix done over the winter but, if it doesn't work this time i'm looking for the best place to send it. And i think your it! I have been fighting sliding 1-2 shift for 3 seasons now and it's getting old!
Discussion Starter · #37 ·
Mav , shipping across the border is a pain to say the least ,and if you did the mod's it should be fine
Frank
i was gonna say my bro in law lives in Soo Canada, and we go there a fair amount i could have grabbed the trans and ship to Frank and bring it back down to the SOO when its done. If all else fails.
WAY UP IN THE U.P?? you still got to cross the mackinac? thats WAY south LOL
21 - 40 of 72 Posts
