1 - 8 of 8 Posts
starting fresh with "new"71 460 and ? c6. been away from fun cars for a while.
need fresh info... 460 and c6 sitting in my barn getting prepped,stock... eng should be good but dont know trans.
c6 questions.
fluid type, anything special.?
how much in mt torq conv?, mt tranns?
how far does yoke go into tail shaft?
dip tube bolt at top, go to top tran bolt or bolt on head?. my tube was bent, repaired,rebent, . its ok but hard to figure where it went.
plan to run with bypass hoses briefly to check shifting. think that will work? (i dont know tranny)
other advice...
Type F would be safest not knowing history
Will hold approx. 12 litres depending on which pan . If converter is out just add a good size cup full in the converter . If it's in the trans never mind it will fill quick.
Yoke should have approx. 1.25" from bottomed for travel
Dipstick bracket usually goes to bellhousing bolt
Yes loop the cooler hoses only as a trial . They must be looped so return oil lubes the rear of the trans
ok, i cannot find any id numbers on it so when needed ill use type
"f"...im just getting stuff rounded up. had an 80/460 mustang yrs ago.
like to do similar. also gotta find a car...!
well, got lost.back again
i finally found the hidden numbers. hope they mean something...
as best i can see, ff e7 ?tp? 7006 da.
e7 i guess is 87 , the others ??
this tran was separate from the 87 460 i got from guys who werent sure about it? seems like it was part of that but its cleaner than the block so i dont know anymore about it.
mainly want to know what juice to use as before asked..
have not run motor yet. got a tran end seal and driveshaft. looking at a 9 inch rr. still collecting stuff..
thanks for help...
1 - 8 of 8 Posts
