Trying to install a Power Pro Chain drive kit in the rail but the stack up is longer than with transfercase. I looked at the early 4x4 FE C6 shaft, still to long.
So does any one make a C6 shorty kit?
Richard
As far as C6-205's go there are two different adapters. Short for pickups and long for broncos.
If you are going chain drive anyway, look for an older divorced tail housing. You can weld the gear on the yoke, because its a bolt on unit, and it makes it about the same as a transfercase with the short spacer.
