The Ford Shop Manual (FSM) is the typical source, otherwise the cam mfgr, or something hopefully reliable such as Summit Tech Pages
the listing for the cam bolt is only 40-45# cause i think that is factory specs on a 3/8 bolt not a 7/16 boltThe Ford Shop Manual (FSM) is the typical source, otherwise the cam mfgr, or something hopefully reliable such as Summit Tech Pages
problem going off that table with a single dowel pin it would be undertorq and could eat the engine (ask me how i know )So what does the cam maker say?
Fastenal has recommendations depending on bolt grade, e.g., 58 with oil on a 7/16-20 Gr8.
[EDIT] After some checking out of curiosity, torque for this part is nearly irrelevant, based on the stresses it sees. Most of the forces are tension, which are very low, and little of shear loads as the tab or dowel pin resist those. Tight enough to secure is good enough if using a thread locker, or tight enough for bolt stretch to retain the bolt from vibrating out if using dry or lubricated. What's tight enough? Try this on from NASA sources which use this chart, adjusting for the KSI of the bolt you're using:
Source: engineeringtoolbox.org
as per ford performance solid roller instrustions i found calls for 65# for 7/16 20If unsure, then use thread locker, and something more than finger-tight.A 7/16-20 isn't going to let anything go anywhere if it stays put.
it does not say so i would assume 65 dryThere ya go. Now all you need to know is if that spec is dry or wet.
