1 - 11 of 11 Posts
Cam - ISKY - Grind No./Type Z-89 SOLIDGood pulling power for drags in heavy car. Rough idle. 3500 Stall. 433-456 axle ratio. 111 compr. Up to 850 CFM Carb.RPM-Range 3500-7500Valve Lift - INT .630 EXT .630, Part # 311-289 with lifters been sitting on shelf but BRAND NEW never installed with lifters $100.00 plus shipping
Edelbrock Victor Intake - Used but nice shape. $150.00 plus ride.
Located in Pa
cam info
Located in Pa
PART NUMBER: 311289 GRIND NUMBER: z-89
ENGINE INFO: FORD V8 1968-UP 370-429-460 CU.IN. WEDGE APPLICATION:
SPECIAL REMARKS: SOLID PRODUCT USE: DRAG
RPM RANGE: 3500-7500
Valve lift is calculated with zero lash and rocker ratio of 1.75
INTAKE TIMING
DURATION: 304 deg.
OPEN: 44 BEFORE TDC
CLOSE: 80 AFTER BDC
CAM LIFT: .360"
VALVE LIFT: .630"
VALVE LASH: .028 HOT
.030 COLD
EXHAUST TIMING
DURATION: 304 deg.
OPEN: 80 BEFORE BDC
CLOSE: 44 AFTER TDC
CAM LIFT: .360"
VALVE LIFT: .630"
.030 COLD
LOBE CENTER: 108 deg. OVERLAP: 88 deg. CAM ADVANCE: 0 deg.
THE ABOVE TIMING IS CHECKED AT .020 (OPEN) LIFTER RISE
.020 (CLOSE)
The following timing is taken at .050" lifter rise and gives a more accurate determination of camshaft position.
INTAKE
DURATION: 264 deg.
OPEN: 24 BEFORE TDC
CLOSE: 60 AFTER BDC
EXHAUST
DURATION: 264 deg.
OPEN: 60 BEFORE BDC
CLOSE: 24 AFTER TDC
How would this work in a 4000 pound street rod with a 4 speed and 3.89 gears? It'll have ported D0VEs, Performer RPM with 1050 cfm Holley and fenderwell headers. I wouldn't go out looking for one with solid lifters but what the heck! I like a rough idle and the 4 speed settles things down a bit but just how streetable would it be?
Pope, I dont know if this woiuld be good for you or not , you might want to ask one of the smarter (lol) board members. The intake will be sold as the order I received the emails in. Although I accidently erased the first person. All pics and answers will be sent tomorrow. Thanks for the interest.
Cam LIfters & intake
I am interested in cam & intake.
Where are you located in pa?
Can you send me your phone #?
Thanks,
Dave
I'll take the cam. I sent you a PM.
Sales pending on both, Items where offered to those who responded first. If deals do happen next in line will be offered. Thanks
is intake still avail?
1 - 11 of 11 Posts
