1 - 7 of 7 Posts
93 COUPE WITH THE INTERIOR FULLY GUTTED FIBER GLASS HOOD GUTTED DOORS FENDER WELLS, 8 POINT ROLLBAR ONE RACING SEAT, THE MOTOR IS A 466 WITH 12.2.1 COMP C9VE HEADS FULLY PORTED ON EXT AND POCKT PORTED ON INT. CAM IS SUMMIT 3501 HYD WITH
.509 INT .509 EXT WITH .218 .228 EXT WITH 114 LSA. SPRAYING 175 SHOT IN IT. THINK IT WEIGTHS ABOUT 2800-2950 WHAT DO YOU THINK IT WILL RUN AND YOUR COMMENTS ARE
OK! TO. HAVE RECONDITION SJ RODS IN IT. NOT PLANNING ON SPINNING IT PASS 6000RPM. I HAVE 4.30 IN IT NOW! BUT I HAVE 3.27 TO GO IN IT TO! TELL ME WHAT YOU THINK!
Get a custom cam if you can 240-246 @ .050 107 c/l and around .600 lift and change the gears to the 3.27s if you have a 3 speed in it.
You have way to much compression for that cam.
JMHO
Blake
:oops: Didn't see the 175 nos change that to a 112 sep and add some exhaust dur.
Blake
Cam it to maximize power as an NA engine then add NOS with less ignition timing. Just did a 520 for a customer. Lobe sep 108. With a 120 shot the difference from peak NA power to peak NOS power at the exact same rpm was 118HP. It moved torque peak up 700 rpm on the NOS pull and made 166#/ft more torque.
WHAT WILL IT RUN IN THE 1/4 Mlles!
JUST NEED SOME INPUT ON WHAT YOU THINK IT WILL RUN
JUST THE WAY IT SIT! :roll: :roll:
1 - 7 of 7 Posts
