Cam for 429/460
Crane Cam pn # 354551, Grind # H-2880-2
2500+ converter, 3400-3800 cruise rpm, 9.5-11.0 compression ratio
RPM Range 2500-5500
Minimum Rpm 2400
Maximum RPM 6000
Valve Float 6600
Lift 522/530, adv duration 288/292, duration at .050 226/230.
Spring requirements
Closed 122 lbs @ 1.900
Open 306 lbs @ 1.400
I was going to use this cam but decided not to. All I did was cover it with cam assembly lube and stuck it in the block.
Asking $100 obo.
