Comp Cams Mech Roller camshaft, springs, and retainers. 460 BBF. Was in a 466 w/ Kasse P-51 heads and ran [email protected] mph N/A. 28, ¼ mile passes total. Bent connecting rod and am now building a bigger engine. I bought the cam to use with ported D0VE heads, but decided to use it with the P-51s and it worked well.
XR280R-10, p//n 34-771-9 cam, duration 280 int/286 exh, lift .657int/.664 exh. ICL 106 Lobe sep 110
Springs Comp Cams 954, 1.525 OD, .730 ID Dual valve spring w/ damper Seat load 210lbs @ 1.90” Open 523 lbs @ 1.25” Rate – 483 lbs/in, Coil bind 1.17” Recommended with the above cam. Ran 28 – ¼ mile passes with a max rpm of 6700.
Retainers – Comp Cams 741, steel, 10 degree “Super Lock”
$280 for all obo
Dave
386-684-0299
text 386-530-1767
