I have a D1VE @ Zero deck with KB137 pistons. I am using D3VE 97cc heads (not ported) and FelPro gasket with a compressed height of 040. What is the compression ratio? What Comp camshaft would be the best for a street driven daily F100. Exhaust is stock manifolds into a single exhaust for now, duals later through a Flowmaster muffler. Rear gear is 3.87 and I use 250x60 R15 rear tires. Carburetor is Edelbrock 650 cfm 1470 manual choke on a Performer intake. I will use a HEI distributor. Transmission is a C6 with stock convertor. I plan to get a "K" kit from Comp Cams. I appreciate your recommendations.
I run a similar build with Comp"s 268 w/.494 lift it works fine
John F.
XE256H ; part #34-234-4
256*/268*@.050" - .487"/.493" valve lift - 110* seperation -
