I had a junkyard 460 that I did the wrong thing with - which is to say a quick and dirty hone, re-ring, and re-bearing. It lasted about 50k in my daily driven 70 Torino until I lost oil pressure cruising on the highway a week ago. I took it apart from under the car and most of the rod bearings were hammered pretty bad. I think #1 spun as it had a weird deformity and major discoloration although it seemed as if the bearing was in the right place idk.
Anyway, I'm kind of pinching pennies at the moment until I get a project done and sold, so I'm wondering if I can put some parts together that I have on the shelf and have something to cruise around for a while, but I think I will be really pushing it as far as compression ratio goes. 91 octane is the best in this area and it gets really hot in the summer.
Fresh 20 over d1ve block, new cam bearings and align hone.
Fresh d0ve heads with comp 924-16 springs
New sealed power h612p +12cc pistons
Stock rods (I think I have enough to make a good set)
Stock crank I will take to have ground
Roller rockers
Edelbrock performer intake
Holley vac sec 750
Points dizzy curved by mad porter to ~16 initial/34 total with a quick all-in
Comp Xe274h or lunati 31605 cam
With those pistons and heads I would be at 10.34:1 static compression. The block is at stock deck height so the quench will not be ideal.
With the XE274h with straight up timing I would be at 8.35:1 dcr
With the 31605 with straight up timing I would be at 9.15:1 dcr. I think maybe there is something about cam overlap and detonation that I don't understand because I always hear this cam can be run with high static compression ratio.
I could run either cam with retarded timing for a more favorable dcr but I've bumped into the limit of my knowledge again and I'm unsure if that's either necessary or a good idea
I can deal with bad street manners it's a 4 speed car with manual everything and 3.70 gears.
Thanks in advance for any input and sorry for the long post
Roller rockers
Holley vac sec 750
