1 - 3 of 3 Posts
is an adapter available? seems easy to make if not.
The only way it will work is if you make an adapter that rotates the ZF. I don't know of any company that makes them. The Small block and big block bell housings have bolts that interfere with each other unless you rotate the trans... Or I guess you could make a really thick one.
Are big block ZFs that hard to come by? Here they are practically giving them away
there are no small flywheels to fit this swap
even if you made a bell to fit a bbf
1 - 3 of 3 Posts
