1 - 10 of 10 Posts
7 qt box pan for use in a chassis car or dragster. Has the kickout, trap doors etc. Screw in style Stef's 110v heater, pan is set up for an external oil pump, has screened -12 pickup tube, -10 return both on drivers side. There are two -8 bungs weled on the sides for external drainbacks I had on the rear of the cyl heads. also one 1/4" npt fitting for an oil temp sender.
Will also toss in a new Ford 1 piece rubber/steel pan gasket.
The pickup could easily be removed and a std in pan type used. I had no issues using this on my doorcar, oil pressure never fluctualed even on shutting down, I went a different route is my only reason for selling. It has also been notched to fit an A460 block where the main caps hit.
250.00 gets it to your door in the lower 48.
[email protected]
1 - 10 of 10 Posts
