1 - 16 of 16 Posts
I have seen in past posts some names of companies that offer carbs that have been tuned to a customers setup, but I can't find their names. Can someone help me out here?
Alan
pro systems, also quick fuel i think that charlie or lem or both are dealers for them . there are a bunch of them out there thats a couple that come to mind brad
Performance Carburetors or P.C carbs in Ontario California.. My 1050 is sweet. A friend imports them over here to Australia..
Quick Fuel Technologies
AED Performance Fuel Components
Ty of TPC carbs is another carb specialist who is occaisionally on this forum (and HotBoat). I think the name of the guy Dave McLain uses is Bobby Oliver (contact info mentioned above).
As posted earlier I would highly recommend using Bobby at Competition Carburetion Sparks NV. 775-331-5609. I was just out there at his shop last week learning some stuff about carburetors and seeing how things are done. He puts a TON of effort into his carburetor builds and each one is personally run on a test engine before it goes out the door. He was telling me that his test engine has been run with over 3000 different carburetors!
If you send your carburetor to him this is about the time to do it because his busy season is just around the corner.
Thanks for the replys
Thanks for the replies. I'll start making some calls, I've got a 1050 dommy now, and I'd like to have it gone through and hopefully set up better for my motor.
Do you know if they have a website?
The only website Bobby has is what I've set up for him. It's very simple and it's tied into our website www.mclainsautomotive.com I did put some new pictures on there the other day showing a few things from his shop, flow bench, carb building etc.
u might try Willy's, in Mt. Carmel IL. he makes his own metering blocks and i think even main bodies for holley carbs. tony stewart and a few other nextel cup drivers run his carbs also. he has an in house chassis and engine dyno, gained us nearly 50 horse at the wheels on our pullin truck.
www.willyscarbs.com
ScottJackson said:
TPC carbs is still around? I thought he disappeared after some unhappy customers.
That would not be a very good statement to be wrong about. I've not heard anything to that effect, he did a good job by the accounts I've heard, he was fairly generous with carb info on the boards and a decent guy to boot, if there's another story, I'm not aware.
http://www.tpcracing.com/testimonials.html
Yes, I sure don't want to sound like I know of real problems with him when there actually weren't. I just haven't seen TPC mentioned on here for quite a while and I do know that the turbomustangs.com guys in general are not fond of him at all.
1 - 16 of 16 Posts
