No, you don't need to move the plug from the power valve passage. No power valve makes the thing a little more consistant tune, and that is the reason for the 6 jet spread from front to back. If the thing had a rear power valve, then the jets would be square.
THe squirter split is a little differnt also. Typically they are done square as well. But with a progressive linkage versus a drag oriented 1-1 linkage I could see why you might get away with a little less squirter shot on the secondary side.
