Have a set of Comp Cams 4017 stud girdles with out poly locks, just the girdles nothing else - Believe they fit TFS or Motorsports A Heads - this pair has been cut down the middle to facilitate install - they are a one piece design so stabilze the rocker studs extremly well - again they are split (looks like with a band saw) to make the one piece design easier to get off and on - I found and used a set of Jomars so no longer need these - $35 shipped in the Lower 48 - can take pics if needed - believe the Comp Cam or Summit ads says will not fit OEM style 460 heads.
