Having a time trying to figure out the charging system on my 1982 Econoline E350, 460 engine. Ammeter always showing a slight discharge, with lights on,or off. Always starts right up. Alternator is a brand new (not reman), and it was tested before it left the store, it tested out as good. Brand new external voltage regulator ,battery cables and new, clean grounds.
This past weekend I let it idle for 30 min, with lights on, was charging @ 11.7 volts. Lights off it is @ 11.9. Battery, also brand new with vehicle off resting voltage is 12.2 volts. It's acting like it is missing an excitation circuit. Any thoughts on what to do next? The STA wire, that runs from the back of the alt, to the electric choke is not connected, as I have manual choke, could that disconnected wire be the culprit?
