1 - 10 of 10 Posts
Ok who makes the best Double adjustable Rear shocks?
I am sorta looking at these Strange shocks. That's the length it looks like I'm going to need.
50-007 Strange Aluminum - rear, double adjustable
19-1/2" extended, 13-1/4" compressed
6.88" stroke, Strange # S-5007
Also, who makes the best Rack and Pinion Pinto style? Looks count but function first.
T
Guest
Jerry, I would say the Strange shocks are very good along with Konis. I know people who swear by Afco shocks. But the Santhuffs are the toughest out there. The shaft is 7/8" & you won't wear them out. I went with the Santhuffs on my car after discussing all of them with Jim Geese at Vanishing Point. He is a dealer for Koni,Strange,Lamb, & Santhuff. Give him a call, he can definitely give you some good advice. Whatever you get, get the longest stroke possible. It makes getting those big meats off alot easier. I run the 7" stroke on mine & need every bit of it when it comes to slick removal. :D
Pinto Rack
Summit has the Pinto rack for $199.95, as does A.R.T. http://www.appliedracing.com ,A.R.T. also has the weld on tie-rod tube/rod-end kits for the Pinto rack too.
Rick Jones Race Cars http://www.quartermax.com has standard width Pinto racks, as well as modified/narrowed width racks. The narrowed Pinto rack (shorter main body & shaft) come in handy in combos where you need a shorter rack pivot point each side (5 1/8" shorter total) to help remove/eliminate possible bump-steer problems.
I would stay away from the Stiletto billet rack unless you are planning on building the Mustang chassis/body really narrow because it's splined shaft doesn't point toward the driver's side.
Amen on the Stiletto rack! But, is sooooo silky smooth and looks pretty. I may switch back to a pinto rack myself. Anyway, on the shocks, the Strange shock are the best for the money. I paid $550 for mine with the springs. Also, you can add the air adjust to them to control the compression side for a stiff launch and then soft down the track. I bought the adapters for $15, the regulator, solenoid, and timer for about $200 more. I already have the CO2 bottle for the chute launcher.
David
T
Guest
I have a Mustang 2 rack & pinion on my car. Jim Geese said he preferred it to the Pinto due to the stronger mounting lugs on the Mustang 2. My old car had the pinto rack & I didn't have a problem. I guess I am neutral on it. Those Flaming River racks look real nice. The Stilletto's look damn good too. :D
Shocks.
Thought I would mention that QA-1 now offers a double adjustable shock too. They have both adjusting knobs (bump+rebound) at the bottom of the shock (kinda like the Strange).
I haven't messed with the QA-1 doubles, and don't know anyone who has. But they might be something for you to check into as well as the others.
Re: Shocks.
That's what I have now. I nver got a chance to run them but they look great. Brand new. Not long enough for the new chassis, they fit the old chassis just fine.
Jerry,
Check out the latest issue of ND. It's got a real good section on shocks. There's more options out there than ever before, and most of them will NOT break the bank which surprised me.
John
1 - 10 of 10 Posts
