1 - 11 of 11 Posts
Comp cams 739 titanium retainers,611 comp 10degree valve locks,4702 spring cups all brand new= $225 retainers alone are $310 thru summit
Hurst Quarter Stick for c-4or c-6 forward pattern =$50
Windage tray for Canton girdle BBF= $20 new
Ford 9in gears 4.56 gears used for less than month in drag car. comes with pinion support and solid pinion spacer, fairly new bearings=$75
Any questions call 1-605-376-4576 ask for Greg
The shifter has the cable but the nuetral safety switch plunger is broke but the braket should be there for the c-4 transmission because thats what I took it off from
The gears are standard ford and a stock pinion support, the pinion had been set up in the support thats why I am including the solid pinion spacer and shims, makes it a little easier to setup.
"gpaulsen" sent me the 4.56 gear set plus the misc parts...Great Buy !
These were in exellent condition ...Good Seller !!!
1 - 11 of 11 Posts
