7.3 is probably about right with the factory resistor wire, hook a test light to ground, then touch the negative side of the coil while some one cranks,should see good steady flashing, if so bad coil if not, bad module or pick up coil. hope that helps
oh also check your voltage onthe positive side while cranking
