1 - 8 of 8 Posts
Have a Comp Cams Roller Camshaft custom grind never put in engine still like new fit 429-460 BBF!
Duration @ .050 289 Intake / 312 Exhaust
Lobe Lift: .510 Intake / .477 Exhaust
Lobe Separation: 115
$200.00
$200.00
Are you sure that that's "lobe lift"? I'm thinking that's probably gross at the valve....;) If that's lobe lift then that cam will gross @ the valve @ .8976" I, and .8395" E. :eek: lol. Of course with those kind of duration #'s @ .050" that MIGHT be lobe lift!!! What application was it ground for?
Rob
Comp Cams BBF Roller Camshaft
Yes the lobe lift is correct to the "T" .510Int. and .477Exh.
Comp gross lift on the cam card was figure using 1.73 rocker ratio= .882Int and .825Exh.
Yes they have a catalog grind close to this but the catalog cam was grind using 116LS/116LC
1 - 8 of 8 Posts
