1 - 18 of 18 Posts
Ace, do you have a Comp # for it? I'd like to run the #'s for my engine on my dyno....Thanks. (it's probably too big for the heads that I have....but it's fun running the #'s any way).
Rob
What engine dyno are you guy's using and what numbers are you looking for. Its a custom grind.
Ace
Ace
I am using Virtual Engine 2000 Pro Edition 2005. I allows me to enter the complete specs under a custom camshaft. This cam gives me about 10 more horse.
EDIT: It would be nice to have the Intake centerline.
Clay
Discussion Starter #14
valve adjust .022/.026
Lift .761/.761
Duration @ 20 .300/.312
Valve timing @ .050 Intake opens 28BTDC Close 64 ABDC
Exhaust opens 72 BBDC close 28 ATDC
Intake center line @ 108
Lobe separtion 110.
Duration .272/.280
Lobe lift..4400/.4410
Play with that
Ace
I'm using the Pro Sim Software with the Dyno5 Sim. It has a cam disc that has (I believe) all the grind specs for every major cam manufacturer (Comp at least, that's as far as I've had time to play with). Just look up the grind # and it injects all the cam events into the formula. Thanks for the #'s. I'll plug 'em in. :)
Rob
Ace
Clay
this belongs in engine tech . but the intake C/L is not fixed . set that number anywhere .
Try different C/L numbers . Cam might be just what you need
1 - 18 of 18 Posts
