Runs perfect and Will be removed from a 1989 f-700 .This is an air brake chassis with engine mounted air pump. It was an old Ferrelgas truck and the engine has been converted to run on propane. There is not a whisper in this engine and the oil is just as clean as the day it was poured in the engine. Most likely this is the steel crank. It even comes with the... If the engine is not what I say I'll buy it back gaurantee. $800.00
