1 - 9 of 9 Posts
This is a used 460 FORD, 496 Cubic inch, offset ground crank with Chrysler connecting rods. has CJ heads with high port plates, Stainless steel valves, Comp Cams Roller Cam & Lifters, ARP Head Studs Comp Cams Triple Springs and Titanium Retainers, Harland Sharp Roller Rockers and Jomar Stud Girdle, Blue thunder cast valve covers, Dooley Flat bottom oil pan, Single plain Edelbrock Intake for Dominator Carb. comes with 1050 Holley carb, BHJ Dampner. Makes about 650 Hp, 4000.00 or best offer, located in south east Michigan, Call 734-762-7665 Ask for Dave or cell 734-778-1399
Last edited by VictoryRacingParts on Fri Jan 18, 2008 9:45 am; edited 3 times in total. The price wasn't there the first time I read it either :) Bump for a good deal though.
whitelighting2 said:
It says it is 4500.00 on the subject line, also is in the post in the last two lines. :wink: :wink:
:lol: :lol: :lol: :lol: :lol:
water passages still open and
can i take the high port plates off,and can you post the cam specs,comp ratio etc.thanks in advance.
1 - 9 of 9 Posts
