1 - 12 of 12 Posts
Saw the writeup in Car Craft on your dyno challenge win.. Can't imagine what the competitors were thinking.. 300 hp seperating the king from the also-rans....
Now we need a 1000 rwhp N/A bbf to take all-motor.. Anyone with a 650+" Boss or C headed motor running on E85 running around out there?
Jim
Any rough idea how much flywheel hp it would take to get the job done? We do have some real stout all motor deals running around the site.
Schmitty,
Generally the flywheel horsepower is 18% to 20% more than the rear wheel horsepower. The parasitic losses vary with such things as transmission, light weight internal parts, convertor, spool or posi unit and so on.
Hope this helps,
c.evans said:
Dan,
That's awesome :!: I'm so proud of you. :D It still sounds like you had some rpm left in it. What rpm did you stop the pull at?
Great job, :wink:
Hi guys ...Thanks for the kind words...
Charlie, it was 7,100 rpm and the HP curve was flat, not gaining. The converter is to tight now and really pulling down the engine, I will loosen it in the spring.
Also that was at about 21 #'s of boost, I was shooting for 23 but I didn't have enough experience with the controller yet. On the local dyno we made 1,840 at 23#'s.
I took it to the track last fall and on a very slick track at very minimal boost we ran a 8:31 @ 170 mph. Here is my best pass and worst reaction time…It does spool really well for the converter being so tight. I am also getting allot of tire shake, In fact the last run ripped all the brackets in half on the rear end housing, I just finished a new chrome molly sheet metal housing for her.
Dan
1 - 12 of 12 Posts
