1 - 13 of 13 Posts
Good going guys between you and Bobby things are a little tuff for the chevy bunch.By the way did you have any problem going down the track?
Thanks for the kind words. Lonnie Rushing was there with us serving up some grilled pork chops. I think that is what brought us some luck.
Thanks,
MarkJ
The adjusted altitude was 3000ft. We had a best of 4.73 at 150. We were running on a 4.70 index. When the car was off I managed to pull .010 and .005 lights out of my hat. When I was off the car managed to get close to the index. Just one of those days when things went my way for a change. Will be doing a 4link change (might have helped us at Windy Hollow) so the car will go down the track more consistant. #1 and #5 are running 100 degrees hotter than the rest even on the small shot of NOS we use so I am also looking at fattening up those to cylinders. Scott is a stand-up guy and I am glad to have him as a friend.
MarkJ
Man that's flying! :shock: ! You all have every reason to be very proud of yourselfs. :D
I've got some receipts & flowsheets to send down to Scott. I just hate doing paperwork! We picked up the flow numbers, especially in the mid-lift ranges. Those new valves have the stellite tips, so there no need to run lash caps, unless you need to for geometry reasons. Also, I think I've already mentioned, they have the radius groove and locks.
Keep up the good work!
1 - 13 of 13 Posts
