1 - 3 of 3 Posts
Purchased from Performance Automatic. This converter is C-6 spline but I'll include a new spline adapter to run it on a c-4. Has anti-balloon plates and stalls right around 4000rpm depending on weight and horsepower. Approximately 200 passes. Worked excellent when removed. $400 + shipping.
Re: Performance Automatic/Continental 10" Race Converte
Brian_Eyler said:
C-6 spline but I'll include a new spline adapter to run it on a c-4. Has anti-balloon plates and stalls right around 4000rpm depending on weight and horsepower. Approximately 200 passes. Worked excellent when removed. $400 + shipping.[/quote
IT HAS A ADAPTER THAT SLIDES OVER THE C4 SPLINES TO LET YOU RUN A C6 CONVERTOR
THANKS GEORGE
Yes. This is a c-6 converter, but the spline adapter slips onto your c-4 input shaft so that you can run the converter on a c-4 (so long as it's the same flex plate bolt pattern). This is just a converter - no transmission. Thanks for looking.
1 - 3 of 3 Posts
