Just a quick sidebar: our internal combustion engines rely on heat as a key component for making power; they also react well to cooler air intake for making power...not necessarily cold operating temps. Also, cold operating temps, such as below ~160* water temperature, actually increases engine wear substantially.... a racing engine likes a cooler temp and makes more power.
I checked them, they don't have any foam.Check the breathers and make sure that they don't have that foam crap inside of them. I bought some K&N air breathers and the engine kept leaking oil. When I took them off and looked inside them they had some kind of foam in them. I took that stuff out and have not had an oil leak since.
Steam? You'd better not be seeing steam. I agree, prolly overtightened.My breathers were breathing before cause i would see the steam coming out of them but i have to admit i haven't seen it do that in a while....
Yeah the first 2 minutes of the engine running steam used to come out of them, i haven't seen it in a long time though it was only after getting the motor together.Steam? You'd better not be seeing steam. I agree, prolly overtightened.
OK i am replacing the gaskets tomorrow, just going to hand tighten them i guess or use a torque wrench and torque them to the correct torque if i can find my book.1/4" valve cover bolts only torque to 7 FT/Lbs, that's about what you can turn on a screwdriver handle......you have to leave enough movement in the gasket so it can expand and contract with the temperature changes.
Rob
