1 - 10 of 10 Posts
Crane Hyd. Flat Tappet cam #354552 with matching lifters and valve springs and retainers. It was used about 2000 miles. The lifters were put in a box in order when removed. The springs work on unmodified heads. Worked nice in a mild 466 with D0VE heads. $175 plus shipping
Basic Operating RPM Range: 2,500-5,500
Duration at 050 inch Lift: 226 int./230 exh.
Advertised Duration: 288 int./292 exh.
Valve Lift with Factory Rocker Arm Ratio: 0.522 int./0.530 exh. lift
Lobe Separation (degrees): 112
Mufflers are Flowmaster Delta Flow 2 chambers. They have turndowns welded to them. They have around 3000 miles on them. $75 plus shipping
Somebody must want this cam. It went 13.50 on 87 octane in a daily driver 76 F100 on regular Pep Boys tires with a stealth, 750, headers, and 3.91 gears.
Hey, off topic... How did that cam run? How did it idle and sound? Ive got the same one and am curious... Havent started it yet.
You will be happy with it. It had nice torque off idle and drove well. Nice mild lope at idle. I drove it everyday to work and college. It went 13.50 in my 76 f100 with Futura 275/60s. Made good power to 5500. With drag radials, a recurved distributor and some carb tuning it probably would have been in the bottom 13s or maybe 12s. It beat eveything on the street lol.
1 - 10 of 10 Posts
